Toyota Auris 2.0 Diesel Bad Fuel Economy
Bev3069
I have a Toyota Auris 2.0 Diesel 08 reg that is used by a family member. Recently I have had the need to use it and although a great car it has really poor fuel effiency. Most my driving is around town
- £40 diesel gave me 213 miles
- £20 diesel gave me 105 miles.
It is averaging around 25mpg. Is this normal fuel efficiency for a 2.0 diesel auris?
When was the car last serviced? How are you obtaining the figures? From the car's range, from the car's fuel consumption display, or are you calculating the fuel consumption? Putting in less than 15 litres of fuel can give false range info.
Can be normal: -  old car, big engine, manual transmission, driving in town, cold weather = equals poor mpg
When was serviced last it’s an important question.
The car was last serviced not too long ago around september. Im calculating mpg based on how much fuel im putting in.
It was last serviced around september. It seems low to me as we have a Rav 4 2.0 petrol which does similar mpg similar driving etc
Well diesel not necessarily means better efficiency, all depends of many things, both cars are very similar Auris and rav4 , the suv is obviously heavier and taller but even so still can be equal in consumption. Btw diesels loose efficiency with age a lot more than petrol engines. , if the car starts and drives fine very likely it’s normal fuel consumption for the model, perhaps some other owners share their experience. There were some posts about egr cleaning of this engine and efficiency increased by far, if you do some research and check on the car too.
Regards
You cannot calculate the MPG they way you are doing it, too many variables, too little fuel on £20 to give an accurate figure. The only way to get an accurate figure is from brim to brim
