1985 hiace column change 5speed stuck in gear in even in nuetral
Pete30nz
Hi group,
We have the above van. While driving, it started to play up while changing gears. Eventually I couldn't select any other gear position that would let me drive apart from 1st gear position. Now while parked with or with out using clutch I cant select 2nd gear position. I can select 1st position which lets me drive forward. 3rd,4th,5th and reverse and even nuetral I can select, but these positions all just stall the vehicle with no movement at all with or with out the clutch.
Any ideas and input much appreciated.
Pete
