Rim Size
Jolie
Can anyone tell me what is the maximum rim width you can fit on a new 2021 Corolla Hybrid?
max size fitted by manufacturer is 18”, you can check sizes here:
https://www.wheel-size.com/size/toyota/corolla/2020/
you maybe able to fit 19” or even 20” but then is going to be a modified version. Best size wheels and tyres for Corolla IMO are 19” or even the 16” as the car will be most comfortable and efficient., performance with good tyres will be as good as with the bigger sizes. 👍
I’ve got 17s on my TS, but it does look a bit ‘under wheeled’. Really needs 19s to fill the arches, but I can’t fault the ride on 17s. . . Maybe I’m getting too old for big wheels now 😌
I have a Bridgestone Space saver from my sold gen 4 Prius, and wondering if it will fit the Corolla....except Thant the Design comes with a spare if so ordered.
anybody need a spare which is unused
As far as I know Prius and Corolla has a different sizes  between the bolts and centre bore.
