Throttle body
Dan Roberts 84
Hi, I have a 2003 Corolla T3 1.4. The throttle body is part number 222100d090.
I am looking to buying a good second hand one. I’ve seen that some places sell the same throttle body but for a 1.6 engine.
my question is...does the 1.4 and 1.6 throttle bodies use the same sensors, or are they different for each engine size?
If a 1.6 would work straight away without having to swap sensors then I’ve seen and good used one for sale.
Thanks, Dan
It's the same part on the 3ZZ and 4ZZ the ecu is calibrated differently depending on its use (if they were different they would have their own part numbers) - you will have to do a TPS relearn or disconnect the Battery for 10-15 mins then drive the car
Swapping a sensor would defeat the reason for changing the TB, also the TPS is factory calibrated for that TB when manufactured
Thanks for your comment 👍👍
