Rattle From either Exhaust System or Kinda Sounds like Timing Chain Tensioner under load when accelerating?
Darren Whelan
When Normally driving Shift Light tell you to up, rattle occurs, if downshifted goes away until next gear needed, no loss of power but i feel just to drive easier,as in not attempt to push the engine, of which iam not(40mph) its bugging me,
Edited by Darren Whelan
didnt finish text.
What engine, petrol or diesel? Since exhaust is mentioned, check the under body shield above the rear silencer or other parts of the exhaust. I had the shield on mine fall and rest on to the rear silencer. The aluminium corroded around the bolt holes. I fixed the shield back in place using large penny washers and some spare pieces of aluminium.
This is only a guess and could be something else, but without more info, it is hard to give a proper diagnosis.
