2012 Estima 2.4L hybrid - engine oil
Eamonn22
Hi , i have checked engine oil level and its nearly at minimum on dipstick, engine has 72k miles...please tell me what is the best oil to get for it folks, i take engine oil very seriously so need to know which one is most suitable for It ?
Thanks in advance
Since this uses the 2AZ-FE engine as found in a host of other Toyotas, the standard recommended oil is fully synthetic. Depending on your location the specification varies according to climate.
This may help: https://www.whichoil.info/toyota/rav4-2-4
As it is a hybrid, as with other hybrids from the same era, 0W-20 was probably the factory recommendation.
Thats great thanks
Excellent info ill go for that one so thanks appreciate it
47 minutes ago, pakman said:
keep a eye on the oil level as 2AZ-FE engine is known to burn oil.
Yeah will do thanks a lot, i just happened to check it and noticed its operating on approximately 30% oil capacity so need to top it up soon, any particular reason why they burn oil more ?
engine design fault.
I think North American 2AZ-FEs may do, but not heard of, or experienced, Japanese ones doing the same.
Thanks Frosty, didn’t note OP had a hybrid!
Thanks for this glad to hear japanese ones may not be affected by design fault piston ring issue, i will always keep a keen eye on oil level so cheers
