Disconnect battery
Pietro Sabbadin
Hi everyone,
I would like to disconnect the Battery of my Aygo 1.0 X-Press (bought in 2020) because for 3 weeks I will not use the car. Do you know if it is needed to have the so called 'radio code' in order to be able to use the car when I will recconect the Battery again?
Thanks in advance.
No code..
Most cars of that age will sit happily for 3 weeks without the batteries draining.
I left my Mk1 for 6 weeks whilst on holiday in the US, it started first time with no problems.
Agree with the above.My wifes Aygo wasn,t used for 2 months recently.It started straight up a few days ago.I wouldn,t bother disconnecting the Battery.
If you been spooked by the batteries going flat on Toyota hybrids, I think you can relax, it is hybrid specific. As long as you haven’t already got a dodgy Battery, or an alternator not charging proper, should be ok.
3 hours ago, Cyker said:
Hmm, so could we fix it by sticking an Aygo battery in our Hybrids?? :laugh:
If it will fit in alongside the usual Battery, sure, why not? A pair of parallel links.....instant Ah upgrade! 😁
8 hours ago, Red_Corolla said:
If it will fit in alongside the usual battery, sure, why not? A pair of parallel links.....instant Ah upgrade! 😁
... until one Battery starts to fail when the other Battery will try to keep it charged and will kill itself as well.
Connecting two batteries permanently in parallel isn't a great idea - where two batteries are fitted (e.g. in a campervan) they are fitted using a split charger system to prevent one Battery killing the other.
6 minutes ago, PetrolDave said:
... until one battery starts to fail when the other battery will try to keep it charged and will kill itself as well.
Connecting two batteries permanently in parallel isn't a great idea - where two batteries are fitted (e.g. in a campervan) they are fitted using a split charger system to prevent one battery killing the other.
It was a tongue-in-cheek remark, Dave 🙂. I wouldn't dare do it on a Hybrid for fear of overburdening the charging system.
I have seen it done on breakdown service vans years ago, because they were forever being used to give jump starts. I guess they rely on the portable units these days. I would imagine they used to upgrade the alternators, too, as that would be the main area of concern.
The welder / fabricator we use has a fancy split charge system on his Transit - the auxiliary Battery is used to run all the led work & orange warning lights fitted to the van.
