Starting with a new Turbo
Edd S
Hi All
I was hoping someone could advise on how best to start my 2008 hiace after replacing the turbo. It looks tricky to prime the oil lines with oil as they are on the underside and so will drain whilst rebolting. I'd like to disconnect something on the electrics to stop it from firing whilst I crank it over. Is there a fuse I can remove that wont throw up an error code?
Cheers
Edd
Press and hold the throttle all the way down, this should put it in Flood Clear Mode (Petrol only) crank it for 10-15 seconds and repeat a few times to build oil pressure
if not, pull the fuel pump fuse or relay
