2014 aygo serpentne belt change
PeterCo7219
Hi how do you loosen the tension on the serpentine belt to change it?. thanks.
I think it's a case of slackening the alternator bolts, it is on our 2013 mk 1 as far as I know.
Hi my Aygo is a new shape mk2 model so is different to the mk1. thanks
What engine do you have, is it the 1.0 petrol?
It's still the 1KR but uses a tensioner (optional to use the pin/Hex key)
Click to enlarge
 Fitted belt this morning no problems thanks for your help.
How ? did you use the special tool ? I ask for future reference
it's called a spanner 😉, no need to lock the tensioner, if you must use an Allen key
Edit. This is for the Mk2 14-22 Mk1 up to 2018 you just tension the belt by moving the alternator
