New to the Forum
killie77
Hi
joined as I’m in the process of buying an iQ
its a 59 plate with a few faults that I’ve negotiated for in the Price. It’s in need of a New Clutch. If I can find out what’s the best Clutch for the iQ. That would be a bonus.
Then have to find someone to fit it 😩
The Drivers Electric window doesn’t go up or down. Can hear the motor running but nothing moving.
Also need a Drivers side mirror as the one it has is cracked.
Any help would be most appreciated
Ian
Hi Ian,
Welcome to the forum
Did you get some idea of parts and labour costs before you agreed the price. If not I would give a couple of local garages a ring to get a rough idea of a new clutch price at the very least. The other parts you can probably pick up secondhand at a reasonable cost. If you have some reasonable DIY skills you can fit these yourself and save some money. Hope this help.
Hi
Thanks for the reply. I’m guessing including the clutch and labour £300-350
My Stepson is an HGV mechanic. I’m hoping he could fit the Clutch. Have seen some kits on eBay for around £120. Not sure of the quality for that price.
Window shouldn’t be a problem. It’s either slid off the Track or worst case it’s the motor. Wing mirror I’ll fix.  I made a point of all this to get the Price way down. Private seller, Guy just wants it gone. When I get it fixed up, I’ll upload a couple of Pics.
Ian
... I would get a decent clutch as there's a lot of labour involved.
( A garage will charge about £800-£1,000 ).
As well as the usual big brands, a poster on here (can't remember who exactly) recently mentioned Exedy as a worthy manufacturer.  I'd not come across that brand before.
https://www.exedy.co.uk/corporate/about-us
Probably me, that's one I had fitted to one of my old diesel Yarisusesies, as I was trying to find a more heavy duty one (London stop-start traffic is murder on a manual gearbox clutch!).
TBH, the best kit would be a Toyota OE kit, but other reputable ones would be fine and probably cheaper too; Luk, Valeo, Blue Print etc.
Clutch is a standard item, LUK will be a very good choice (assuming it's a 1.0 619 3117 33, but you may have to buy a clutch and pressure plate 619 3117 09 and a new slave on its own purely down to parts availability) if it's a gearbox issue be aware the gearbox is unique to the IQ, Mirror 20 quid for an aftermarket one £75 for a genuine
Window mechs are a very common fault, Valeo (oem for Toyota) make a modified part
From a previous thread
"What part do you need to be aware that the regulators has an improved design (made by Valeo)"
Left - 851108
Right - 851109
Fitting destructions -
cost wise £60-100
unless it's dirt cheap leave well alone, you're looking at £5-600 in parts, the same again in labour, a gearbox issue is likely to be another £1000 - by the sounds of it the car has been neglected so allow for a full service, fluids and potentially new brakes and tires - that cheap car doesn't look so cheap now
Also if its white look for paint issues especially on the roof and bonnet
Hi
Thanks for all the Replies. Have watched a You Tube video regarding replacing the Clutch. After watching I’ve decided to give the Car a miss. I do appreciate all the advice.
Many Thanks
ian
  • Like 3
The engine and box are a bit tight, a simple-ish job with a 2/4 post lift, i wouldn't like to do it on the ground with axel stands or ramps - there are plenty of IQs about at all prices
