Aircon issue
Budz
My Ac turns off itself and the light also goes itself after around 15mints of use. However the fan continues to blow. The cool air also seems not that cool anymore. Ive had the new condenser put up 4 months ago along with new gas. Ive read on the Internet to this could be an issue of the aircon relay. The trouble is I cannot locate to exact which one is the aircon relay and on the manual those two blue colour relays are not showing either.  Can someone please tell me with the issue symptoms this could be an gas leak or the relay? Also, can you please gelp me to find the location of the relay and the OEM number please? Tia!
Have you had the AC scanned for codes ? Manual AC or  Automatic AC (climate) ?
No i havent run the obd scanner. Manual ac
Be inclined to scan the system first as already mentioned, to see whether there are any fault codes displayed.
