How to add sat nav to my Yaris
Thomas76
Good morning all. I was wondering if someone could please help me with an issue. I originally had a stereo in my Yaris which didn’t have sat nav on it but I’ve recently got a sat nav module from eBay and I was wondering how I could get it to work please?
pre or post facelift ? Did you get the correct module type for your current radio, did it come with the cables and GPS antenna
Hi. I got a complete stereo and module but it didn’t come with any cables or the antenna.
can you give me the part numbers
Hi I found this. I hope it helps
86842-YY010
86101-YY070
86705-YY030
plus the GPS antenna as well.
They are for the Touch only
the touch and touch2 are different
show me a picture of what you have
Touch is 6 button and it uses the older style Nav module
the touch2 uses the later Nav with different cables
_MG_1446.JPG.18c6128b69356a23b49af772ad8
Hi my one is the touch 2 gen 1. Hope this helps.
I don’t know sorry. When I get 5 minutes I’ll take a photo and post it on here for you ( just got home from work 😞😞😞).
Why not save time and just buy one -
7 hours ago, flash22 said:
What nav module did you purchase ?
image.thumb.jpeg.a17ae7268b7405fd7554ff4b9cc4d599.jpegimage.thumb.jpeg.a17ae7268b7405fd7554ff4b9cc4d599.jpegIt looks like the one you have on this photo if that helps you.
Some like to make use of what is already there, it's also bigger than a normal standalone one. Personally I wouldn't go through all that trouble, the position of the screen is not appropriate to use sat nav.
I use a standalone Garmin stuck to the screen for best of vision, just 4.3". Will be using it to visit Sissinghurst Castle Garden shortly. Good luck with it OP.
86842-12010 is the cable, and you will need a gps aerial (GT5-1s plug)
The sat-nav on my 2019 does the job but the graphics are a bit clunky the worst thing about my system is i have tried several times to get my phone to work with the map so i get live traffic  updates and i have failed so many times i gave up.
I will use google maps and android auto on my next Toyota.
I have used on of these in the past rather than stick the sat nav to the screen.
TomTom Sat Nav Beanbag Dashboard Mount £8.63 click and collect @ Argos |  hotukdealsimage.jpeg.10ef4559be18a4893a94a42bfcebffca.jpegimage.jpeg.d1588b4005fb06594fd400a98e8d770d.jpeg
