Cant get in my car
Svenin
Have done the wd40, not a budge, I removed the logo and drilled a hole in the openmechanism and was able to open the bonnet, messured the Battery and it has 12,9v all fuses in the engine comp. Is fine.. both key fobs are flashing red when pushing the butten, its a keystart car
Try tapping on door when turning key, try spare the spare key.
Can you open the boot door then try the inside handle.
Last resort a long block of 2by 2 wood inside wheel arch front drivers side and hit it with a hammer(it simulate a crash all locks open in a crash).
Reset it, take off Battery terminals for 1/2 hour. Maybe somebody has put something in your key hole, that is stopping it from turning?
What about the boot or other doors, do they open?
Not sure which fuse controls the doors?
hi try to think what you done lately or add to the car, try to think what you did yesterday, change the key Battery (in have sensor in it also), disconnect the Battery and try open it without the Battery off, if wont open then its something with the door mechanism, try to open the trunk, try the spare key i think the key itself damage and you wont be able to turn ignition on also ...
don't go far away most of those things are made from stupid small issues ... try to think logic.
New Battery in key today, no help, but i was able to open the car with a string and some help today, car starts but keys dont work to open the doors, ac controll dont work and cabin light dont turn on when opening the doors, all fuses good…
