Diagnostics
pakman
Hi can anybody help. I have a 2007 Toyota Estima petrol engine. Lost all power and engine management light came on. The vehicle would restart and no management light on the dash. I have called a couple of garages re Diagnostics, just to check it out, in Ipswich where I live but they are unable to help as it is an import. Does anyone know of a garage in Ipswich or surrounding area that may be able to help me. Thanks
Thanks for your reply but looking for somewhere nearer.
You could of course consider buying your own.?
I believe something like the Ancel JP700 JOBD scanner will work.
You can get one on eBay for about £80.
Thanks will look in to this.
update i bought the ancel jp700 plug it in and got 3 fault codes p1603 engine stall history. p1605 knock control cpu malfunction. p2103 throttle actuator control high.
Thanks will give them a call.
Thanks for the update re. the Ancel JP700.
went to my local garage and they said i need a new body throttle and that will sort the problem. got a used one from eBay £80.
