Alternator
Edm
Hi all
need to change the alternator on my 2015 1.2T auris .The problem is the intercooler for turbo is mounted above it
Do i need to remove intercooler to do this job.If so is there a procedure for same ,also the serpentine belt seems to drive 5 pullys
1 is crank shaft ,2 water pump ,3 A.C , 4 alternator ,anybody what the fifth pully drives ,it is run by the smooth side of the belt
Thanks Martin
Hi Martin, from a previous post Flash22 answered the pulleys question below my comments.
Can you get to the bolts out without removing the intercooler. Have you looked at the access from under the wheel arch cover you should then be able to see the pulleys and belt config. Hope this helps.
There doesn't seem to be a lot of free detailed information available for changing the alternator on the 8NR FTS engine.Hope this helps and hopefully another member maybe able to give you more information.😀
Going clock wise.............................
A/C
Crank
Tensioner
Alternator
Idler
Water Pump
Out of interest, Whats wrong with alternator?
Bearings? Brushes? Mileage?
A/C
Crank
Tensioner
Alternator
Idler
Water Pump
Hi Bob thanks for your reply will have a look at your sugestions
your right very little info on the 8NR FTS ENGINE ,MAY BE TOO SOON not all that long on the market
Thanks again for taking the trouble to reply
Hi Solero
Seems to be a bearings issue .160,000 km
Thanks for reply and kind regards Martin
Hi,Martin, From what I have been able to find online there doesn't seem to be any real issues with the Auris 1.2T,but Iike any car that has high mileage parts will wear and need replacement. I have a bit to catch up with you as I only have 44.200 miles on the clock.
Let us know how you get on with the alternator and if I can find any additional informative I will let you know.👍
Whilst your swapping alternator , do check the tensioner pulley for any play. Let us know how you get on.
Hi all
up date on my alternator problem .Spoke to a auto elec. buddy
he had a look and is pretty sure auxellery belt tensioner is my problem (thanks Solero) .he thinks he can source alternator ,waterpump,
and tensioner second hand from crashed Auris with much lower mileage
PS WAS ON AUTO Doc website They have a lot of repair videos
Nothing on this type of auris,but a person can request they make a video
any car .put in request on replacing alternator which should cover tensioner
etc.They say when they get enough requests they will post video
Great Talking to yu guys and Thanks
A problem shared is a problem halfed
Will be back when i hear from my buddy
On 2/11/2024 at 12:44 PM, Edm said:
Hi all
One of the guys on the "8nr fts" thread faced same issue, but got garage to do under warranty. I think the tensioner and pulley was about £200 new. He had problems sourcing the new part.
What does the noise sound like?
Good luck and thanks for keeping us updated.
Hi all
Yes Solero parts hard to come by especially the tensioner with pulley .I am told by Toyota garage that it is unique to this engine which was only used for about 5 years But good news my buddy the auto elec has sourced them second hand from second hand parts dealer ,awaiting arrival
As for the sound like something is running rough or grinding sound
Thanks all will get back soon
Doctor car parts on eBay selling new for £80. Original Gates part.
Alternator Pulley FOR TOYOTA AURIS 15->18 1.2 Petrol E18 8NR-FTS 116
Is this different from tensioner pulley?
Found it!
£28.69 | MJHK 16620-47060 Drive Belt Tensioner Assembly Fit For Toyota AURIS C-HR 1662047060
https://a.aliexpress.com/_EwRw9U9
Worth the wait for the slow boat from china? At Least its new. Not sure how long it will last though. £45 delivered.
Thanks Solero good hunting from you. Second hand parts are on the way
from 2016 auris 58000 km on the clock crashed and scrpped
Found a Japaneese site amayama car parts japan
worth a look as they show diagrams of the car with the parts numbered
They seem to have every part good price
Thanks all Talk soon
Cool, i use partsouq.com for exploded parts diagramd.
Would be worth changing subject to "8NR FTS Tensioner Pulley / Alternator" or similar to help others in the future.
Hi all
up date my buddy done the job replaced water pump,belt tensioner and alternator with used parts also new serpentine belt
He had to remove INTERCOOLER to get access ,said it is not a big deal
just needed new gaskets from main dealer
So that’s the story will keep the car another year or 2 now
and hope all goes well
Thanks to all for showing interest
