3L engine layout
Jessie1994
Hello, been off the forum for ages while rebuilding my seized 3L engine, 1994 Campervan.  It's been so long since we stripped the engine, and can't remember where the last few bits go!  Does anyone have images of the top of the engine, where, I think, should be a fuel break vacuum switch, with two vacuum pipes off the diesel pump on the other side of the engine, which cross over the rocker box.  Thanks, Steve
Thanks Bob.  Still can't see where the two rubber pipes belong(one from the vacuum diaphram above the fuel pump, and the other seems to go to the front of the vehicle).  Could these be for the aircon, which I've abandoned?  They run across the rocker box.
LH1136048723
Sorry about the duplicates!  This seems to be the item I need. Any thoughts about finding one?  Thanks again.
Built  - 10/1993
Model - LH113V-RRPDS
I think it may have had an engine swap at some point with an earlier engine can you find the engine number on the block
LH1136048723. Thanks  found this on toyota.epc-data.com
Quote
I’ve highlighted the VIN, above. Ta. The code on the website isn’t right - it seems to default to the Grandia / Regis for some reason.
your car comes up as a Hiace/Regiusace
Your picture is of a LY101 etc., which is the truck version of the hiace 1995 onwards it also has a 2L engine
ah found the info, it's under heating, and a/c it was a dealer option to idle up for the A/C
https://jp-carparts.com/toyota/partlist.php?maker=toyota&type=711140&cartype=77&fig=8717
88031-25020 is the complete kit
i would start with checking the resistance, I assume you have done this and found it to be dead
Edit. magnet valve (aka soleniod) 88690-95J39
Quote
Good stuff this, gin!  So does that mean that I can blank it off, since I’ve abandoned the air on?
OK, so the part that I have lost is described as follows:
VALVE, IDLE UP. 88690-95J39. Toyota don’t make them anymore. Anyone know where I can find one, and since I’ve abandoned the air on, do I even need it?
all it does is activate an actuator, that idles up the engine (increases rpm when underload of the A/C) it's used in hotter climates like Asia
block off the vacuum feed and abandon it and/or remove the actuator
Many thanks Bob!  That’s solved a multitude of issues. Thanks to all.
