Sienna window defogger/ defrost settings
Cbehr
In the winter Months I’d like for my defrost setting to remain from the last setting.  When I auto start they are off.  Any ideas?
Hi Carolyn,
Some vehicles have settings that allow you to customize the behavior of certain features, including the climate control system. Have a look in your vehicle's owner's manual or settings menu to see if there's an option to set the defrost settings to remain on after using auto start.
You could also use the remote start feature Instead of using the auto start feature, if available on your vehicle's key fob. This may allow you to start the vehicle with the defrost settings already activated.
If all else fails, you could consider installing an aftermarket remote start system that offers more options for the climate control settings. These systems often come with more advanced features and can be made to suit your specific preferences. But are certainly expensive.Hope this helps.:smile:
