Door Trim Panel stuck
grocerybag420
I'm trying to remove my door panels however my front passenger side door panel will not unclipped. I've tried the rear one and it unclips really easily however I've put alot of force into my front and it just won't budge. Does anyone know how I can open it without breaking any clips or anything?
Hi Ahmad,have a look at this video it may not be your exact model, but it is a Yaris. It will give you an idea of how the panel comes off. If you haven't got a trim removal tool use a flat screwdriver wrapped in a cloth.
Make sure you haven't got any screws that may be stopping the panel from coming off. Use the screwdriver to carefully prise round the edges of the panel.Hope this helps.:smile:
https://youtu.be/kfI2wWp8-04?si=CSQSmvRfaXdpJdJO
3 screws 1in the door release behind the plastic cap 2 under the window switch trim, the rest is clips
if it has never been off, it can be extremely tight you need a trim tool or a taped up screwdriver to pop it off, start at the lower left of the door card
@Bper the vid is of a second facelift Yaris (lhd) but its pretty much the same for all MK3s
Thanks for the help guys. I managed to get it off after a while of tugging and loosening it as it was extremely tight as you mentioned if its never been taken off before.
