From LAS VEGAS, 6th generation Celica 1999 lift back manual
elmizzo
Posted (edited)
Main Engine Wire Harness replacement from junkyard.. no repair manual all common Sense
Edited by elmizzo
Las Vegas raised
Topic moved to the Celica forum.
Do you need a repair manual to fix your car?
Yes, please! Thank you so much. I'm missing something from ONE wire I think. The starter is good and new stack. Do not start the car. I'm going to take pictures. Maybe Solenoid
Needed it after all
I guessed from your name that you might explain better in Spanish   😄
Two repair manuals:
Engine - 3S-GE
Chassis & Body
You didn't say which engine you have. Maybe the 7A-FE, 3S-FE, 5S-FE.
Wiki - Toyota Celica
5s-fe ... It seems that the motor relay or the one next to it click when I try to start the car and it's the relay box that is by the alternator and it's a manual transmission
8 hours ago, elmizzo said:
...and it's the relay box...
Check the "starter relay", page 460.
