Where's My Nipples Gone
gus
hey folks got a problem with the cooling system on a 5MGE engine, she seems to using water in a large amount and am having to top it up on a more than regular basis.
am doing all the usual things and i have not got any leaks etc the water just seems to be evaporating.
now i know cars use water but not at the rate mine is.
my question is for the technical minded amoung us
WHERE THE HELL ARE THE BLEED NIPPLES
cant find them anywhere and they are defo not on any of the hoses
Thanks in advance (photos would be excellent help)
:thumbsup:
there's a drain at the left rear bottom side on the radiator and one on the right hand rear side on the engine block.
Headgasket blown?
Cheers, Yves.
wish i could help!
I know where mine are :P, On my t*ts! :D
You have t*ts? Man t*ts at your age?!? My god :lol::ph34r:
Headgasket blown?
thanks for the advice mate. its not the head, that was my first thought as well as the "oh my god this is going to cost"
but has it checked at a garage and the head is fine, so is the radiator and all the pipes. hhhmmmmm :help:
ignore those drain plugs those arn't for air , but you knew that :thumbsup:
arn't celicas self bleeding via the header tank ???
good question, well presented,
dont know mate, even so would have still thought that there would have been a bleed nippple somewhere for the water. :eek:
WHERE THE HELL ARE THE NIPPLES
:thumbsup:
Cheeky !Removed! sod !!!
if you cant find them mate you're buggered, and theres no way i'm sending you a photo!!!
:thumbsup:
:lol:
:thumbsup:
But I can if it means you'll do mea better deal on the mk2 if your still thinking of selling her :lol::lol:
I have four...... three perfectly normal ones..and a tiny ickly fourth one....
Thought I'd share that with you all :-)
Just a thought dude but is your radiator cap air tight? Is it possible that vapour is escaping through the cap?
If your radiatorhas no leaks and neither have your pipes, and your water pump isnt leaking, and your head hasnt gone.....then i have no idea :lol:
Im sure that doesnt help in the slightest B) :lol:
You say she drinks the water. Does this only happen when ya motors in use?
Ie does she still pi%% water out when not used for a few days?
I'd guess that she loses water when running. Either you've got a loose hose/jubiliee clip somewhere, or the rad cap / expansion hose cap is knackered,
or the rad is holed, or as you have previously ruled out the head gasket has gone.
Vipes
I remember on my old 7M-GE supra, I hada pin hole in one of the heater matrix feed pipes... it never "leaked" but when she got up to temperature it steamed out... but was easilly missed!!!!! I alsways noticed a steamy engine bay.. but its only when it went properly that I found the leak!!!!!
Thay also tend to drip from the rad bottom drain plug...
