Celica Abs Sensor
crashbang
to get the light off the dash for the mot , cut the wires on the multi plug from the sensor not the main car end under the wing liner and join the 2 wires together , light on dash should go off. :thumbsup:
this is how i found the faulty sensor on my 95 st202 .
already tried that one. i also tried putting resistor between the two wires of the same resistance as the sensor and that didnt work either
