Tyre Valves..
daktari
These are the flush fit valves stay clear of them.. they look good but.....
read this thread
The special adapter that comes with them is easily broken and you have to buy a full set to replace them... and wat happens wen u loose it???
Get a set of normal high speed metal valves :thumbsup:these are better
Yep. Had my doubts about the flush fitting ones. Opted for the anodised alloy bolt in jobbies. Thanks for the info. Much appreciated. :thumbsup::thumbsup:
