Quick Help Question
jdbecks
hi all
just wonderin if any can help me, my girlfriends 1996 fiat punto rear left indicator dont work when she brakes....wondering if anyone can help me???
Dodgy wiring perhaps?
Have you had a look at the wiring - perhaps wiggle it a bit - might be a loose connection - thats my solution to everything! :D
Other than that, I really couldnt say.... best bet if your not sure with electrics is to take it to a garage and they can check it out! :thumbsup:
when she is braking, or foot held on the brake, she tries indicating but the indicators dont work
That is usually down to a bad earth connection on the bulb holder.
Check that all connections are tight and dry :thumbsup:
poor earth or water inside the lamps mate had same problemsgice em a clean inside an WD40 all the connections
cheers for all the help peeps!! ill let u know how i get on when i look at it ;)
Agreed, it sounds like a bad ground or a short.
yeah it was the earth!
cheers peeps :)
Happy to help :thumbsup:
I used to have a punto ........Infact I had 3
-_- -_-
