T-belt Light Reset 2.8l 3dr Prado
VLADY
can anyone tell me how to reset the T-belt light on my prado?
it´s a japan import make.... :help:
All depends on what year it is, if it's an early one you will have a rubber bung in the dash panel glass, use a small stick to press the button.
Let me know if you dont have this and I will find the procedure for the hard way of doing it.
mine is a 1999 model....
there´s no rubber bung in the dash panel neither the two screws in the back of the dash panel......
there´s no rubber bung........i´ve taken the dash panel and did not find the screw either...
mine´s a 1999 model....
It should be one screw and two holes, if you dont have that then I cant help.
Sorry
