Urgent Help Needed
pedro7680
As you all know i recently suffered a disasterous engine blow up in the gen 5.
well now the cars been sitting crying for attention for too long, the sunny season has given me the chance.
what im after is a link to a .pdf file if anyone knows of one or a site, that explains the basics of how to dismantle and re build an engine.
im planning on reading it and slowly taking it all to bits then slowly repairing it.
if someone could be so kind to point me in the right direction..
thanks
toyota say the bottom end crank bits broke.
not 100per cent sure whats happend, but id broke at 100ish and suddenly all power went and a strange metallicy nosie. wouldnt start after that
Check out the pinned celica manuals at the top!
Also MR2 manual might help as they share the same engine gearbox. I'm guessing yours is the 3SGE engine?
:rolleyes: Yeah its a 3sge by the looks of the car....may be wrong..hope it goes well fella, got my fingers and toes crossed for you :thumbsup:
at least ive got it back. means i can slowly piece it back together.
thanks for the support peoples
I assume that you will be removing and refitting the engine block and head+manifolds as one piece. It is a real !Removed! to get the head plus manifolds on the block with the block in the engine bay!!!
Just my ten penneth, I wouldn't want you to go through what I did when my head gasket went.... Good luck!
keep the comments coming.
im wanting as much info as possible before we tackle this job
