Remote Key Lock.. Help
wolfenstein
greetings,
i need advise on what to be done..
had problem with my rav-4 door lock..
remote doesnt work... even w/ a new Battery. :(
.. even if i do it manually.. my key wouldnt turn when i do it..
have no problem with my key in the ignition though...
my 4x4 is equipped with a toyota security system...
pls.. help..
I am sure that someone on the 4X4 /RAV section of the forums will be able to help.
Sounds like a remote programming problem.
Best of luck :thumbsup:
..that's what i thought so...
the key remote has a visible dial in it.. guess its the setting of its frequency to the transponder..
..somebody might have played & turn it (kids probably).. now it doesnt work..
tnx anywys..
It might be an idea to see if your local Toyota Centre can advise...............advice should cost nothing..........they will give you a quote for any rectification.
