Best Tires
zebidi
right, my wheels are being exchanged for a new pair of the same but 16, what are the best measurements for this? I am currently running 17x7 super legs with 205/40/17 toyo t1r.
Will 16x7 with 195/45/16 still rub the arches? will the tire be wide enough to protect the wheel? if i do 205 again will this hit again?
Also, has anyone tried the parada 2s? i'm thinking of having them instead.
Thanks guys!
I would go with 195/40 R16 and if you can't get them I'd go for 195/45 R16. I'd also stick with Toyo's, I've got the T1-S on mine and they wear pretty well and grip like no other imo. :thumbsup:
If the car has been lowered, go for 195/45x16.. these shouldn't rub.. depending on how low the car is (30 - 40mm should be ok). 195/40x16 will be hard to find.. off the top of my head you can get Dunlop SP9000 (around £90).
Yokohama Parada 2's will stick to the road like s*** to a blanket, but are quite a soft compound, Toyo T1-s or T1-r's will give as good a grip, but could last you a bit longer... and there won't be too much difference in price (shop around, the net could be the cheapest option)
i have 195/45/r16 on a 40mm drop and only time i get any issues is
1: full car
2: two up front and big big as dent in road
