Distributor?
Poppy
Hello, I have a 91 Toyota Carina Auto Exec. When the engine is warm/hot and moving slowly or coming to a stop frequently (say slow moving traffic) it often cuts out and sometimes won't re-start for a few moments. Often there is a very quiet click after stalling. My research so far suggests ignition module in the distributor, the ignitor unit (is that different to the module?), or, less likely perhaps, a stuck choke or vaporising fuel. Any confirmation or other suggestions very gratefully received.
Many thanks
Neil C
The Ignitor unit in the distributor does give problems(expensive to replace),so would start with the basics first :
Carry out Compression Test - it's pointless doing an Engine tune if the compressions are down !!
1) Check and regap/or change the spark plugs.
2) Check the HT Leads.
3) Check/adjust Ignition Timing.
4) Check/adjust valve clearances.
5) Check vaccum pipes on carb/inlet manifold for perishing/splits.
6) Check operation of PCV Valve on Rocker Cover.
7) Buy a tin of Carb.cleaner(aerosol) and with the air filter off,clean carb. air horn,choke butterfly+linkage and choke body.
8) Check air filter element and refit - reset idle speed and Mixture.
Process of elimination at the end of the day.
:thumbsup:
