New Yaris Spec
Kerby
ok just been goin round the toyots.jp website lookin at the Vitz and come across the spec for the new yaris
LINKY
now am i goin mad or is it my bad guessin transalation but does it look like the 0-60 on the t-sport is 10.5 sec, 0.5 faster than the 1.3 :wacko: which means it is 1.5sec slower than the current t-sport
Are you sure you're not reading the numbers for the auto?
A
i think its gonna get heavier and slower, as the Aygo is now the diddy car, and toyota may build them a bit bigger and more 'substantial'... maybe
mk1 p1 still rocks the roost :P
Google language tools ;)
Clicky!
Sadly it can't translate where there's text on pictures though...
A
im sorry did i not just quote that????? :ffs: and for a start rays family is from honk kong, which speek english and chinese i believe. right.
TYPE_____2SZ-FE___2NZ-FE___1NZ-FE___2SZ-FE___2NZ-FE
TYPE_____Serial 4 cylinder DOHC___Serial 4 cylinder DOHC (all of them)
Inside diameter___ 72.0×79.6__75.0×73.5__75.0×84.7__72.0×79.6__75.0×73.5
× distance mm
Compression ratio_____11.0__10.5__10.5__11.0__10.5 (not 0-60) :rolleyes:
Total cubic displacement_____1.296__1.298__1.49__1.296__1.298
The highest output ___64(87)/6,000__64(87)/6,000__81(110)/6,000__64(87)/6,000__64(87)/6,000 (yes kids that means that the tsport will deliver 110 bhp)
Largest torque___116(11.8)/4,000_120(12.2)/4,400_141(14.4)/4,400_116(11.8)/4,000_120(12.2)/4,400
Fuel FEEDER________ efi (electronic control type fuel injector)
Fuel tank capacity_________L 42
Use fuel unleaded regular gasoline
i give up now, im board, but theres isn't any 0-60 figures on there as for vehicle weight im not sure theres 2 figures, gross vehicle weight @ 1335 and vehicle weight @ 1060 i know which one i'd like it to be but im not sure which one it is???
Quote what?
I would say that 1060 kg is the unladen weight and 1335kg is the maximum permissible weight.
:thumbsup:
A
have you seen the pics
looks well heavy and i think it is going to be "bigger"
Its MAHOosive..its y they release the aygo,because the yairs has got bigger.
