Electrical Problem?
GnzYza
Hi All,
On my 99 1.8 Avensis, the interior light went, central, etc....PROB was due to DOME fuse!!
But my interior light blew a bulb a few days later, THE DOME FUSE is ok thou. ANY IDEAS!!!
Also my orange ecu light comes on occasionally??
And sometimes my temp needle dont work, unless i wait a while with the ignition on before starting.
Is this an earth problem or something any one had this problem and found a SOLUTION??
I know the ecu warning light must be summat to do with a senosor or something out.
where are the bunch of earthing contacts located??
All help much appreciated.
Pop a new bulb in. It won't really blow because of another problem elsewhere.
Sticky guages have been known on the Avensis.
You need to find out why the check engine lamp is illuminating. Read off the fault code, and see what it is. This may give you a clue.
