Disconnect Toyota Alarm/immobiliser?
Neil Clark
MR2, 1992
Is there anyway to disconnect these? remove a fuse?
Had a cat1 fitted and they arnt happy together! :ffs:
Thanks again team, what would i do................... :D
Neil
Hello Mate, I've found the wiring diagram for the Toyota Immobiliser in my workshop manual, it is on my site at the following links:
http://www.overtyre.co.uk/MR2/Imob1.jpg
and
http://www.overtyre.co.uk/MR2/Imob2.jpg
This will tell you the parts location, and the wiring diagram, should be sufficient to remove it, and wire everything back up.
It looks like it works by cutting power to the starter motor relay - so maybe if you remove the connection from here to the Immobiliser ECU, you can bypass everything? Anyway, and half decent mechanic should be able to help you out - and if you get really stuck, I'll see if I can figure out how to remove it, but not having seem one of these in the flesh means I can only theorise.
I hoping it is 'doubled' wired into the other systems i.e. door lock motors etc are wired independently to the Immobiliser ECU as well as to the normal car systems and not wired throught the Alarm ECU which would make things a little tougher. It looks that way, meaning you can just disconnect the wires that go to the Immobiliser ECU and everything will still work,
Hope this helps :)
P.S Let me know when you have the info, I don't want to leave it online for long - copyright issues etc.
  • 2 years later...
Hi, I was just wondering if you caould send me the same information on the toyota immobiliser? And if it would apply to my toyota rav4 2003 model? :)
and
Hope this helps :)
  • 4 years later...
hi i need to remove the immobilizer out of my celica gt to fit my new one any ideas dean thanks all.
  • 5 months later...
