?engine Light?
DBR
right peeps, a bit of confusion:
the orange engine light on the right hand side of the speedo is being a bit temprimentle on me :angry: ,
when you turn the ignition an the lights iluminate, welll the engine one doesnt always join in??
sometimes it comes on sometimes it doesn't .... any ides what this could be, the bulb is obviously still working, could it just be a bad connection?
thanks
Bad earth!!!!!!
I had to fix one earlier this year on a Mkiv (na too!) the panel easily comes out, take it about and make sure its all a tight fit and connections are clean etc....
It just requires some fiddling :D
cheers m8, an yes its just a loose connection had the dash out last night an had a bit of a fiddle an all seems to be working :thumbsup:
