Power Problems
stephenc
1987 SV21 Camry Auto
When I adjust the throttle position sensor correctly, I have noticed that the car surges when cruising to a stop and rpm reduces to about 1,000. As a temporary fix, I have adjusted the TPS so that the IDL points do not close. What causes the engine to surge when the contacts are closed. I have also turned the idle screw completely close, yet the engine seems to idle a touch above factory settings. I have also noticed a lack of power when accelerating from stationary. Once moving, the car has plenty of power. It also now tends to ping on hot days. Any help would be much appreciated. The air intake pipes looks fine. No cracks. Thanks.
