2.0 Diesel Timing Data
popps100
first HI m new
could anyone tell me how to time up a toyota liteace 2.0 diesel ,( timing marks ect )
were could i get workshop manual book or disc
:crybaby:
The timing marks are normally pretty clear on them - the only thing you should do is to lock the Pump pulley with a couple of M8 bolts through the threaded holes in the pulley once all the marks are lined up - this prevents the pump moving.
Carefully check the belt tensioner for wear - the bearing wears on them.
Try "Googling" for a Workshop manual.
:thumbsup:
first HI m new
:crybaby:
The belt is already off and pump as moved so i need to time it from scratch
gugen pin on crank up for tdc,,,spot on camshaft gear at top? ,,, there seems to be no marks on pump pulley
AM I CORRECT SO FAR
help please
Pump moved - Not good - What's the Engine Code ? (2C,3C-T,2L ??)
HI THE ENGINE IS A 2C-T
