Suggestions To Mod Starlet Gt
cosworth_1978
Hi Guys,
I am driving a EP80 fully converted to EP82,I have done nothing much to the engine except porting & polishing, I was disappointed by the power becos I have been smoke by civics with B16A & B20 engines far too oftenly, time to pay back!
How to make it a kick ***** weapon against civics?
I am running the factory standard 0.8bar on high boost.....
Wish to know wat is the maximum turbo setting without further strenghtening of engine parts?
Is it possible to fit in a 5E clutch & flywheel into my current 4EFTE?
you should hold your own against civics anyway.. ?
but, best thing to do is get the engine breathing properly..
straight through, no cats zorst.
then a nice air filter with a good cold air feed.
that'll get it revving alot more freely.
after that you might need a FCD bcause you'll start hiting fuel cut early and loosing power.
after that up the boost a little and you should be able to rape civics.
and as for internal strength.
theres a guy in new zealand running 27 psi on standard internals.... just need to set the compression correctly
