Car Audio Setup Queries/help
req02
Right I'm planning my system and have come across the following components, I have no idea what I need I only know I want lots of sound. Is the following a compatable and decent setup?
I guess im missing one amp. Is it best to run subs off a mono block or would a 2/4 channel amp work adequatly?
PIONEER DEH-P480MP £81 headunit
MOSFET 50W x 4-Channel High Power
Vibe QB69 £78 rear Speakers
RMS Power 200w
Peak Power 600w
PYLE 6.5 INCH 400w £24 front component Speakers
6.5'' 4 Ohm Midrange Driver
200 Watts RMS/ 400 Watts Peak
1'' Titanium Dome Tweeter
50 Watts RMS / 100 Watts Peak
LANZAR MXA282 £86 amp
4000 WATT 2 CHANNEL HIGH POWER MOSFET AMP
2 x 1000 Watts RMS at 4 Ohms
2 x 2000 Watts Max at 4 Ohms
1 x 4000 Watts Max at 4 Ohms Bridged
2 x 1650 Watts RMS at 2 Ohms
2x PIONEER TS-W3004SPL £128 subs
2x 12" SPL Component Subwoofer
3000 Watts of Maximum Power
Nominal Power Handling: 750 Watts
Thanks for any input
No idea, not having heard a single one of those bits of gear! Decent rule of thumb though, you get what you pay for (and all car audio is vastly over-priced!).
I run my subs in 'stereo' (2 channel). works fine. Are you really going to be running 4??
After some extensive searching, not a bad unit
Vibe QB69 £78 rear speakers
RMS Power 200w
Peak Power 600w
Bit excessive for rear speakers
PYLE 6.5 INCH 400w £24 front component speakers
Very bad choice in front speakers.
Your rear speakers cost 3 times as much as your front speakers.
You should be making the difference the other way round, more at front than rear unless you like your sound from behind you.
You should hear the music infront of you, so the can get the idea of left and right staging.
Are you planning to run your entire system from this one amp???
What enclosures are you planning to have for these subs, boxed??
Will it be sealed or ported??
Having 2 subs will make alot of sound, and having your 6x9 in the back will be useless
I think you need to tell us more of what your planning to do with your system, will it be full out sound, or more towards quality??
Tell us your music taste, drum & bass?? Techno?? Solo Artist??
Are you just aiming to get as much music as your can for yourself, or are you considering for others, like passengers in front and rear??
My system in my car is VERY simple, Alpine H/U with changer attached, into a 5 channel amp, feeding to 2 way active compenents at the front with 1 sub in the boot.
Your setup is close to mine, what you should do, improve your choice for front Speakers, find some mid-range for the rears and subs in boot.
You will need some passive crossovers for your front Speakers, and possibly a filter for the sub to make everything run off the one amp, run the rear mid-range from your H/U. How does this sound so far??
Ok, give me some feedback of what i said, and see if i can help you any more
Bing
:thumbsup:
