Scangaugeii Group Buy!
alanbradley
Hey folks!
I've mentioned this to some of you before, but I'm looking to buy a ScanGauge unit for my car and thought that if more of us were interested then it should be possible for us to build up some sort of discount - if even in the postage from the Greek distributor.
If any of you are in doubt what a ScanGauge can do then here's the linky to their site. Before you look, here's a summary of some of the features to whet your appetities...
Scan Tool
The ScanGaugeII allows you to troubleshoot your own car, read error codes (DTCs), and the conditions present when the error occurred. You can also turn off the "Check Engine" light and avoid those costly trips to the mechanic.
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off the "Check Engine" light
* Tells you when vehicle is "Ready" to pass OBDII testing
* Make and store up to 10 rewritable special codes
to send to the vehicle computer
IT EVEN READS TOYOTA-SPECIFIC ERROR CODES linky!
Digital Gauges
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
* Fuel Economy
* Fuel Rate
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
Trip Computer
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used
* Trip Fuel Economy
* Distance to Empty
* Time to Empty
* Fuel to Empty
Loads of Other Stuff
Easy to Operate
* Simple on-screen operation
* 4 menu driven soft keys
* User settable update rate (Slow, Normal and Fast)
* A HOME key to quickly return to the start screen
User Settable Backlight Display Color
* 7 Standard screen colors and a custom setting with 63 possible colors.
* Backlight for night use
* Both display and keys backlit
* User settable Off, Low and High
* Big display - 50% larger than the original ScanGauge
Automatic Power Control
* Automatic delayed power-down after engine shutoff
* Automatic power-up when engine is started
* Manual power-up with delayed power-down via HOME key
Non-Volatile memory
(stored information is not lost when disconnected)
* User settings automatically saved
* Up to 10 user commands can be stored and recalled
* Today, Yesterday and Tank Trip data automatically saved
* Vehicle settings automatically saved
Easy Installation - no Tools Required!
* Cable detachable at the ScanGauge II. Can be connected on the back or side.
* Easily move from vehicle to vehicle
* Compact Size - just 4.8"W x 1.5"H x 1"D
Bought "normally" this costs £114.50 (or 3 visits to Mr T and less than practically all the ODB2 kits I've found on the 'net). I've managed to negotiate it to £100 Iincluding postage.
I already have firm orders for 2 and would like to make it to 5.
Either slap your interest up in this thread or pm me...
:thumbsup:
Alan
PS This comes highly, and personally, recommended to me.
Darn, meant to mention that this is a great investment if your Toyota doesn't respond to the "diagnostic paperclip" (ie D-4D amongst others) and is fully transferable between vehicles of all makes...
:thumbsup:
A
