Hi-lux 4wd Hub
hiluxman
i have took the 4wd hub off on the front of my hi-lux and the spring that engages it and disengages it has snaped - any one any ideas why? and is it possible to buy the spring on its own or is is bought as a complete set
Hello hiluxman.
Chances are the spring had become brittle, have come accross this in the past,
I cant see why you shouldn't be able to replace the spring or maybe change the hub. A manual freewheeling hub is about £55 new for the HiLux pick-up and HiLux Surf
Not sure if yours is a pick-up or a surf, but you could try these people http://www.milneroffroad.com
they will be able to sort you out.
The service they give is brilliant and the prices are very reasonable and 99.9% of the time delivery is next day if you order B4 3pm
Paul
thanks will try them
by the way it's a pick up
cheers
