Replacment Bulbs
bwalk
To bwalk,
I have 03 plate T3s. Presuming trim is near enough the same to later model 07 plate, should be quite straight forward. Lift felt trim from rear of your centre consul, reveals 2 x 10mm bolts, remove bolts. You should be able to remove rear section of trim to reveal retaining screws for gear lever trim & shroud, also side trims that your leg would be next to. You should be able to access rear of rotary switches now. Also good excuse to check h/brake adjustment at this stage & clean any dirt out that may of lodged around g/lever trim. I think if I remember rightly 2 bulbs to each rotary control.
