Cold Air Long Apexi Scion To Yaris
petrolhead
i have fitted two short induction kits to my t sport but both have lost torque or had flat spot so i went for a long ram from the American xb scion 1.5 £40 on eBay along with apexi filter again £40 eBay had remove 2 inch from filter end of pipe and shorten braket . remove headlight removed top nut from alarm siren then bent siren down on lower braket also bent top braket down out of the way . not a bad fit a bit high just hitting bonnet heat sheild . No flat spot no lack of torque more top end power at last. more new picks with added heat sheild
Very nice looking piece of kit ! Well done.
That realy is a long pipe, what kits did you have fitted prior to this that reaulted in flat spots and torque loss ?
