White Smoke Coming From Landcruiser
dpughe
I have 2005 3 litre turbo diesel Landcruiser. Recently it has started bellowing white smoke when the car is started from cold. This only lasts a few seconds, but the smoke is very smelly. Any ideas?
David
David
Have they elected a new Pope? ;) :lol:
Seriously is your oil overfilled?
David
If its a bitter ,acrid smell,then its probably coolant leaking into the cyl overnight. This means either a crack in the head ,or a head gasket needs replacing.
The sooner its fixed ,the cheaper;)
Blue smoke= oil
Black smoke= over fueling
White smoke= water
David
How about changing the fuel filter (diesel filter) and see if that makes a difference.
white smoke is the diesel fuel not burning properly
so if its only when starting from cold, may be a problem with the glowplugs.
or the pump may be out of sync and not injecting properly untill the pressure has built up in the system
a more major problem may be a lack of compression when cold, which could be caused by iffy valve seats or pistonrings.
but it is more than likely your glowplugs or water getting into the combustion chamber somehow.
  • 9 years later...
Did you ever go d out what the problem  was
The OP hasn't posted on the forum since their first and only post in June 2008, so we don't know whether the issue was resolved.
