Lc Colorado 1998 Suspension Lowering
Stancolorado1998
New here, so please bear with me!
Have a Landcruiser Colorado 1998 whose suspension needs lowering 7cm/3" to get in it into a low-headroom garage!
I have no roofrails on it.
Are there standard kits for this/what's your experience of what and also who's best to do it - and rough prices!
Thanks in advance,
STAN
Thanks in advance,
STAN
Is it currently raised above its normal height??
If so you can refit the original springs.
If not,I doubt you can lower it 3 inches from stock height and have no wheel rub when loaded or on full lock. If you could it would be useless as a 4wd so you are probably better off leaving it as it is or buying a car that fits.
The ony other way is to put smaller wheels on it and that would look silly and so would a suspension drop
