Satnav Help
roger134
Hi. I've just go my new Prius, very pleased with it. One thing (and I may be missing the answer in the manual) - how do I cancel a route guidance (but still see the map) if I no longer need it before reaching a destination? I can see how to suspend it in the menu screen but there seems to be no 'stop guidance' choice anywhere. Thanks
Hi Roger and welcome!
When in map view, touch the ROUTE command on the screen and you will then be given the option to delete destination.
You can use the voice command as well by saying "DELETE DESTINATION" and following the prompts.
Hope this helps
Chris
Hope this helps
Chris
Thanks - I knew I had missed something
Roger
