How To
kimi
How to disable the passenger seat belt beeper:
Hi, try this procedure:
1) Sit on the driver's seat. The passenger's seat should also be occupied.
2) Insert key and turn to ON position.
3) Set the trip/ODO display to ODO (not trip A or trip B ). If it is already in the ODO mode, you’ll need to cycle through the options until you reach Odometer again.
4) Release the button.
5) Press and hold the button again and while you are still holding the button start the engine. Keep pressing the button.
6) Count exactly 14 seconds.
7) Buckle the driver's seatbelt quickly.
8) If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
9) Press Trip/ODO to toggle the mode
10) Wait till the display changes back to ODO
11) Done
Thanks to Goran3456 who originaaly posted this.
  • 5 months later...
11) Done
has anyone tested this?
if mine is disabled .how do i enable it?
Why would you want to disable the passenger seat belt beeper? I can’t think of any logical reason to do so. If you have anything on the front seat that the sensors pick up causing the beeper to go off, plug the seat belt in!
yer but the passenger seat sensor is stupidly sensitive, ive had a six pack of beers on the seat and its set the beep off, its an absolute joke, many thanks to whoever posted this info, im gonna go try it in a bit, il let you know how i get on :)
11) Done
Or, just plug the seat belt in... Job done :thumbsup:
cant u do this with the drivers seat belt as well :unsure:
  • 3 years later...
lol this is going to sound stupid but how do you cycle through to odometer, my corolla only desplays the millege of the car in the speedo and it has a trip computer built in the headunit (Stock toyota cd player)
