Gearbox Removal
delboy21
not as hard as the manual makes out dont have to drop subframe or touch steering rack
take off all plastic undershields, undo both bottom ball joints draw out driveshafts support engine with jack take off 3 engine mounts and all acessories (Battery tray earth strap clutch cylinder etc) and lower jack slightly take off bellhousing bolts and drop tranny to the ground back engine mounts abit tricky but not as hard a job as i thought hope this helps someone
