2005 Corolla Verso 2.0 D4d- Fuel Filter Change
Relayman
Do I need to bleed the system when Ive changed the fuel filter, if so how? Apparently its not a self bleed system on this, and before I take it apart I need to be sure. I also need to know whether theres pressure on the pipes when I diconnect them for the filter housing.
Cheers
Relayman
You'll lose a little fuel when you disconnect pipes but shouldnt be under alot of pressure. As for bleeding, there should be a black button on top of the filter housing. Once the new filter is on you need to press it till in gets hard. Then try starting engine. May need to this a few times before it will start and run properly.
Hope this helps mate.
