Reinforcing Sub Woofer
vmail
Hi, my 2nd sub woofer was fallen out of the box twice now, If I reposition the sub and screw it back in I'll run out of space soon
will something like no more nail do the job or is there another method?
I cant use a bolt form the inside because I dont have access to it
I think that No More Nails with probably crack when you crank up the volume :)
I'm gonna try bigger screws, but if the sub still falls out I'll need another plan
the other sub is still in
Use same screws but coat them in wood glue as you screw them back in.
Remove it... save weight :P
