Mr2 Struck By Cat Catastrophy?
mark1978
hello, last year i bought a toyota mr2 roadster 1.8vvti. Now the thing is, is has run for about 50.000 miles. Now it doesn't run very well at all. It hardly passes the 3000 rpm, max speed is about 115km/hour.
Can anybody tell me whether this engine is still in for a rescue??
greetz,
Mark
Welcome to TOC...
We need more info on what the problems are... can you give more details?
Also... have a read here and do the relevent checks as described.
Good luck.
Hi and welcome to the club :thumbsup:
Pre-cat failure is not the cause of engine problems but an end result of prior faults. ;)
Have you got a CEL (Check Engine Light) showing?
If you do then the code is needed to determine a possible fault. (Information HERE )
Do you check your oil on a regular basis (At least once a week)?
If not and you have recently found the oil level to be extremely low then you may be too late and the apparent problems now are not a good sign.
If you have none of the above faults check out the article on "MAF cleaning" and other useful hints HERE
As Davy said, without more information it is difficult to offer advice, hopefully the above might steer you in the right direction :thumbsup:
Hope it isn't too serious and please let us know what you find.
Les
