Avensis Petrol Engine Making Noise Like Diesel Engine
QIB
I have just bought a Toyota Avensis 1.8 petrol (07) which has only done 13500 miles on the clock. The engine is making noise like a diesel engine. the noise becomes clearer when the engine gets hot. I have changed the sparks plugs but the problem is still there. Does anyone know what is wrong with it please.
hello
i have not faced with such problem during 6 years.
may be your exhaust system got blowed?
are you sure your statements are correct?
cheers/Igor
An "07" car should still be under warranty.............(3 years)
You could ask your Toyota dealer to take a look
I also have an 07plate 1.8L Avensis, 15K on the clock when I bought it (ex-Toyota car from a dealer), now done 21K, engine has always sounded fine.
Surprised you bought it if it's as bad as you say, but as Red Yaris 54 suggested take it to a Toyota dealer pronto, because something sure ain't right with it.
Since it's a 1.8 VVTi, have you checked that there is any oil left?
Well spotted James. A distinct possibility with a VVTi engine but at 13500 miles wouldn't be a very good advert for Mr T. Warranty should cover whatever the problem is. I don't see what good changing the spark plugs would do with the symptoms described, I think that was a shot in the dark.
thanks for your suggestions. Oil is fine. I think that I will have to take it to the toyota to get it sorted.
