E10 Headlamp Problem
corolla16si
Hi everyone, first time posting and hope you can help.
I have a 1996 Corolla SI,i have a problem with my main beam in that they aren't working, all other lights including dims are wrking ok. when you flick onto main beam or use the flasher,the relay in the engine bay energises and the blue light in the dash comes on,but no lights, using a circuit tester with main beam on, i have power in all 3 wires in the bulb block connector,at a guess i think its the stalk on the steering column is wrong, but just wondering has nyone else encounted this problem before,or has ny other insight, they started working again for a few days but have stopped again. i'd appreciate any help thanks
well how you keeping, have u checked if it is a bad earth some place? if u need parts i have an e10 scraped!!
